Transmission Problems
Old Aug 26, 2008 | 10:43 AM
ricseay's Avatar
Default Transmission Problems
My 1998 mazda will not shift properly. Transmission pan was leaking and ran low. REpaired leak, added fluid but it will not shift from second to third gear without letting off the gas. Any ideas on what needs to be done?
Old Sep 9, 2008 | 07:47 PM
piggylover1985's Avatar
Default RE: Transmission Problems
2.5 or 2.3 engine ? any code ? if it's the 2.5 than you have a G4A-EL when it ran so low on fluid, any thing run too low on fluid is not good,you might burned out the 3rd clutch pack, then the transmission will need a rebuild or another one, but bring it to a tranny shop, to have them do an EDS (External diagnostic service) for you, like $39.95 or so they will tell you if it's can be fix externally w/out pulling the unit or not, your transmission it expensive to rebuild, wish you all the luck.
ZoomZoomBoom?
Mar 10, 2011 09:59 AM
Protege99
Dec 9, 2006 10:11 AM
dunnowhothisis
Oct 26, 2006 01:09 AM
danmbruck
May 23, 2006 06:17 PM
miguerh
Sep 12, 2005 01:16 AM
