Temperature dial not working
Friends,
The temperature control dial on my 2000 Milly quit working the other day and I haven't a clue why. The display, mode selection and fan works fine but I can no longer adjust the temperature on the dial. It is stuck at 77 degrees.The "auto" button in the center of the dial turns on but you still can't adjust the temperature. I'd really appreciate any suggestions. Chris |
RE: Temperature dial not working
I just looked at a similar problem on a 98 last week except it was stuck at 72.
You might try popping the dial knob off and making sure that the shaft going into the control head is actually being turned. If knob base is broken then this can cause the problem. If knob is ok andboth the display and heater output temperature are both stuck at 77 then the dial switch has failed in the A/C amplifier. This switch is unfortunately not available as a separate service part to repair. The only serviceable parts are the knob and illumination bulb.[:@]The entire A/C amp/ control head assembly is available and it runs just over $600 for the part alone. |
Really appreciate the suggestion. If you could indulge me one more time and tell me if there is an easy way to pop that knob off without breaking it or the plastic around it I'd be eternally grateful. Thanks again for the information and let's keep our fingers crossed it's just a knob problem only.
Thanks again, Chris |
It should just pull straight off like your radio volume knob. Warming the knob with a hairdryer can sometimes help loosen a stubborn one. Am not very optimistic that it is the knob but sure am hoping that it is. Was wrong on the price of $600. There are actually two pieces to the unit as shown in diagram below. The front part that you seein car is the climate control unit, and rear is the A/C amplifier. The control unit retails at $839 and amp is $720. Suspect you have control unit problem.
[IMG]local://upfiles/1377/CCFF2FBB8E994F4895E2F7C5B21F00BB.gif[/IMG] |
Should get a chance to work on it over the next 3 days. Thanks for the diagram and instructions. I'm sure it will come in handy.
Chris |
If you do find that the climate control is faulty and not just a knob then check link below for a very good used parts locator. You can even look in your own state or locale and compare prices. Part to look for is the Heater/AC control. Can get what looks to be entire assembly for $250 or so.
http://car-part.com/ |
I'm having that same problem. I took my car to the dealer and they're trying to charge me $1900 for the part alone. Is that right? The guys says that it's has it's own computer. I've checked online for used parts and i found a few good prices. Can you click on the link and let me know if this is the correct part I would need? It's the same issue StrobyEMT is having.
http://www.autopartsfair.com/mazda-u..._controls.html Thanks in advance. I really appreciate it. :D |
Originally Posted by VampLestat
(Post 107501)
http://www.autopartsfair.com/mazda-u..._controls.html Thanks in advance. I really appreciate it. :D i finally found one: http://cgi.ebay.com/ebaymotors/1995-...Q5fAccessories price is high, tho. see the amplifier attached to the back? it is white. make sure you get that. |
OMG, Thanks a bunch Keninn. That really helps. If I can do it myself, then I can save myself tons of money. I really appreciate it. Thanks!!!
:D |
I have the unit coming in tomorrow. How do I pop out the older Heater / AC Controller?
