Supercharger questition
Old Jul 18, 2007 | 09:14 AM
Captn's Avatar
Default Supercharger questition
Question about superchargers. I would like to know if a failing supercharger thats not putting out the air volume would cause an engine to run on the hot side. The engine after a normal run seems very hot and has correct fluids and new thermostate.
Many thanks...
Old Jul 18, 2007 | 09:56 AM
keninn's Avatar
Default RE: Supercharger questition
i dont think so. the cooling system on this car is excellent, if everything is up to par. the more air is compressed, the hotter it gets. most common symptom of dying compressor is oil consumption. you will see it on startup, and hard acceleration. the most common overheat problem i read about is failed fan system, not just the fan, but the system too. check to see if they come on when they are supposed to. if the car is ok at speed, but heating up at idle, fan system is a good bet.
Old Jul 18, 2007 | 01:20 PM
Captn's Avatar
Default RE: Supercharger question 1995 Millenia S
Thanks for the information, I defiantly have oil situation, burns lot at start up so have often thought that supercharger is on the horizon.
I have heard the fan running but sitting in traffic with full a/c on, often shuts off where on other vehicle's I've owned, using full a/c brings on both fans continuously.
Do you know where the fan circuit is located, I will defiantly check this out further.
As a note to this, I fitted a switch which controlled the fan relay on a 1984 Vet for the same reason and ran it when in traffic etc. If I could find the fan relay on the millenia, would maybe do the same. The Mazda is an older car and a switch is cheaper and more reliable than starting to change circuit boards and other.
Many thanks for this...
Old Jul 29, 2007 | 01:22 PM
mazda4life's Avatar
just had the same problem about 2 months ago.. The super sounds like its definately shot since mine burned oil like crazy at the start up but always rean fairly smoothe after. When we opened up the compressor (super) it was practically filled with oil. About 3500 can later and she was back on the road good as new. Why would i spend this much... Drive it youll see.
steelgoat
Jul 18, 2006 03:10 PM
madd__hoppz
Jan 28, 2006 08:02 PM
lostbethus
Jan 6, 2006 11:10 PM
ARCVN76
Aug 27, 2005 03:13 PM
cvillareal
Aug 6, 2005 05:09 PM
