service codes???
Old Jun 29, 2005 | 07:47 PM
kickerzx2's Avatar
Default service codes???
a friend of mine is tryn to fix his 2.3sc and we are getting a ses code of 1402 which has to do with the possion sencor for the egr valve. the computer is getting the right signal but still getting a code. any of you come by this before?
Old Jul 8, 2005 | 11:00 PM
gtxtreme's Avatar
Default RE: service codes???
P1402 : EGR valve position sensor circuit malfunction.
At PCM connector #3, 3A light green with red stripe, reference voltage 4.5-5.5v, should have the same at the EGR connector. At 3R
red with black stripe, 0.2-4.7volts, using hand vacuum pump connected to EGR valve port, applying vac voltage should change.
Some times carbon can build up under the EGR valve pindle, just enough to make the PCM think the valve is open. Trick of the trade,
remove the EGR position sensor, three small screws, NOTE: with care use a round flat face punch and tap straight down on the pindle
end, looks like a nail head. This usually removes the carbon and seats the valve. This works for small EGR leaks at idle as well.
simmonsp5
Sep 21, 2023 04:49 PM
Kuki Nayacakalou
Nov 1, 2014 01:28 PM
gman65
Aug 17, 2005 02:12 PM
Metric
Jul 12, 2005 09:23 PM
mnooch
Jun 27, 2005 06:42 PM
