Rattle when braking
Old Oct 9, 2007 | 07:06 PM
Marjnal's Avatar
Default Rattle when braking
My 1998 Millenia is making noise and it is kind of driving me crazy! It is a standard sedan with 110,000 mi.
I have a distinct rattle coming from the rear of the car just when I brake on a bumpy part of the road. It is not apparent when going over rough spots, only when I brake. It sounds like something rolling around in the spare tire well. I took the trunk apart looking for anything loose. I also removed the back seat and looked at everything I could see from there. The rear shocks were replaced 20,000 miles ago. I have replaced the front brakes, but not the rear. I did not remove any wheels, but I examined everything that I could see or touch around the wheels and suspension and found nothing that I could see that would make any noise. Could it possibly be brake pads,etc.? I have had the car for 8 years and want to keep it longer.
Thanks, Al
Old Oct 9, 2007 | 08:38 PM
keninn's Avatar
Default RE: Rattle when braking
look at your rear brake pads. if they are worn, you might be setting off the wear sensor. basically, it will make a scraping sound when the brakes are applied. this means the pads are about worn out, and you need to change them now.
darladoo
Oct 22, 2009 08:21 PM
joeman
Apr 21, 2008 12:56 PM
dbirch2
Oct 3, 2007 04:15 PM
dulcetcalamity
Nov 2, 2006 02:15 PM
C. Goodfellow
Sep 27, 2006 04:49 PM
