Newbie here
Old Oct 18, 2005 | 03:46 PM
legendman's Avatar
Default Newbie here
I have just purchased a 2000 Milly S w/ 62k it has the miller cycle sys. I'm assuming it a sort of a supercharger ???
once i pop the hood what should i be lookin for as far as maintenance.
Old Oct 18, 2005 | 07:28 PM
dancerman's Avatar
Default RE: Newbie here
Main thing at 60k miles is the timing belt. If it still has the original, you should seriously consider a new one. Supercharger is a Lysholm compressor and requires no maintenance.
Old Oct 18, 2005 | 10:11 PM
silverracer18's Avatar
check all the hoses and wires for any rips or tears
Old Oct 19, 2005 | 11:10 PM
babyhuey's Avatar
The 60,000 mile service on the Millenia S is very extensive. If you have the owners manual it will list the things recommended. The spark plugs are due for replacement, valve adjustment is also due, the timing belt is advised at 60 unless vehicle was initially registered in CA, NY, NJ,RI, PA, NH, MA, D.C., and a few other states. Then it is recommended at 105k. I would say replace at 90k would be fairly safe. Coolant change and auto trans flush should also be considered it the fluids are dirty and a good brake check would not hurt since you are the new owner. Fuel filter is never recommended for replace according to Mazda but we all know that 60k is a lot of fuel thru it and would not be a bad idea.
gijoe24jp
Jul 21, 2005 04:29 AM
mark
Apr 25, 2005 07:10 PM
J35TER
Apr 22, 2005 07:09 AM
Daniel4982
Dec 25, 2004 02:12 AM
hottrx8chic
Apr 20, 2004 05:51 PM
