millenia 2000 check engine light
Old Jun 3, 2010 | 09:26 PM
angel94's Avatar
Default millenia 2000 check engine light
egr boost sensor circuit?
Old Jun 6, 2010 | 09:27 AM
VampLestat's Avatar
Red face
I've had my "Check Engine Light" on for a while as well. I had it fixed at my mechanic who is no longer there. It seemed to be 2 oxygen sensors were not working. Well after a year, the light turned on again. It's really annoying since I had it fix the prior year. I haven't had it fixed yet, but will let you know when I find out what it is this time.
Old Jun 9, 2010 | 12:52 PM
SSB's Avatar
SSB
mine came on today as well.. took it to AutoZone and it pulled a vapor code (cant remember the code number) but the AZ person said it was most likely the gas cap. I am not sure i need to reset the CEL after tightening the cap or not.. but will do it tonight and post what i get...
Old Jun 9, 2010 | 01:47 PM
keninn's Avatar
if you fix the problem, the lite will go out. it might take a couple starts. if you erase the lite, then you reset the system readiness monitors, and it takes several drive cycles at different parameters to bring them back on board. if the gas cap dont fix it, this can be hard to find
Old Jun 9, 2010 | 09:28 PM
SSB's Avatar
SSB
i did not reset anything and am just waiting to see if it goes out.. i will keep posting my results
Old Jun 13, 2010 | 07:57 PM
SSB's Avatar
SSB
replaced the gas cap with a new one and the CEL is still on. Should it turn off immediately or should it take a couple of trips.
Old Jun 14, 2010 | 07:33 AM
keninn's Avatar
IF if was the gas cap(which is very common), then it should go off right away. if you disconnect the battery, or pull the room fuse, the ecu will reset. again, it will also reset all the system readiness monitors, and it will take several drive cycles to bring them back on board. if the ce lite then does not come back on, you know it was the gas cap. if the lite comes back on, and throws the same code, then it is not the cap. it is very difficult to find the leak, the easiest way is a smoke machine. a good shop will have one.
Old Jun 14, 2010 | 08:21 AM
SSB's Avatar
SSB
Much gratitude.. i will reset and go from there and keep posting my results.
PervyGeek
Jan 1, 2013 01:52 PM
chrisg
Dec 31, 2008 12:56 AM
Cataphract
Dec 8, 2007 02:50 PM
msparker505
May 19, 2005 10:20 AM
msparker505
May 10, 2005 02:21 AM
