Malinium 2001 S
Originally Posted by keninn
(Post 86788)
74.63 is suggested list. tasca discounted price, 51.49
p0302 cylinder 2 misfire (could be plugs and or wires l think) p1113 lysholm compressor malfunctioned (what is this never heard of it) P1402 egr valve position sensor circuit malfunction (need to find it) P1526 air by pass valve solinoid valve (which is the main problem for it running rough and "limp mode" as you have stated. Bottom line, now l can start eliminating one problem at time. On a side note. I thank you very much for your expertise. Relatively mechanical inclined and do 90% of the work myself once l know what it is. Your experience and wisdom is very appreciated. From Germany l will save you a beer. Heinz |
Originally Posted by Heinz
(Post 86829)
I thank you very much. Just had the car diagnosed. It came up with po300 randum misfire (plugs or wires)
p0302 cylinder 2 misfire (could be plugs and or wires l think) p1113 lysholm compressor malfunctioned (what is this never heard of it) P1402 egr valve position sensor circuit malfunction (need to find it) P1526 air by pass valve solinoid valve (which is the main problem for it running rough and "limp mode" as you have stated. Bottom line, now l can start eliminating one problem at time. On a side note. I thank you very much for your expertise. Relatively mechanical inclined and do 90% of the work myself once l know what it is. Your experience and wisdom is very appreciated. From Germany l will save you a beer. Heinz p1113 is intake air temp sensor(compressor) open or short. cant help you there, i dunno where it is. the egr position valve is part of the valve itself. check the connection to be sure it is ok, the other possibility is vacuum related. 1526 is abv vacuum valve, KJ02-18-741A, and is becoming very common. it lives in a row of 4 solenoids, back of the engine. to the driver's side of the egr valve, you will see a row of 4 solenoids. the vacuum is the one closest to the driver. tricky to get at your first time, i had to remove the entire bracket to get it off. good luck |
M
(Post 86787)
Malinium 2001 S
(Post 86788)
The part number you need is KJ01-18-100C. The list price is 201.61, and your price at our website, tacsaparts.com, will be 139.08 each plus the freight. Why not check out our tascaparts.com store site? We have a full selection of OEM Parts for Ford, Lincoln, Mercury, Mazda, and Volvo. We offer the best prices on the web, and a complete selection, for all your parts needs! Call us at 1.800.915.3141, and we can answer any questions, or process your order, right over the phone! Thank you ! Tony Medeiros |
(Post 87290)
Here is what l was quoted.
I wanted solinoids and this is what they responded with. this is the main thing i need right now. "1526 is abv vacuum valve, KJ02-18-741A". So I am trying everywhere to get this part. Thanks Heinz
(Post 87364)
P1540
Hey Keninn
hope you are well what would be the best way to fix this code? Thanks My son bought a 99 mazda Millinium with someone elses problems and he is really bumed out hope u can help |
Originally Posted by Glennacosta
(Post 95026)
Hey Keninn
P1540
TCS/TCS OFF light does come on
don't know what the and limp home mode is thank you for your Quick reply if we do all this and the problem still accurs what do we need to do next? Thank you |
| All times are GMT -5. The time now is 09:20 AM. |
