main fuse
Old Feb 17, 2006 | 03:41 PM
fmarypoppins's Avatar
Default main fuse
how do i get the broken main fuse out of my 99 millenia
Old Feb 17, 2006 | 08:49 PM
bkey71's Avatar
Default RE: main fuse
First you must remove the bolts holding down the underhood fuse box so the whole box is loose in your hands. After it is loose you can tilt it and look where the blades of the fuse go down in the box. There will be a small plastic cover on each side that need to be removed. You should now see a 10mm bolt holding each leg of the main fuse in. Remove the bolts and slide the fuse out and replace. Now reverse steps to re-install. The main fuse is held in by bolts due to the large amount of current that it handles and needs to have a good connection.
kevenj
Apr 17, 2008 12:48 PM
Fevered
Feb 20, 2008 11:51 AM
Q187
Jul 31, 2007 08:07 PM
archtk
Mar 13, 2006 08:58 PM
brenthebe
Feb 6, 2006 08:47 PM
