High Fuel consumption
Old Mar 9, 2010 | 05:44 PM
MazdaSilva's Avatar
Question High Fuel consumption
My 2002 2.5 Millenia would average no less than 20 miles per gallon after using a full tank of gas now it's around 16 miles per gallon.
The car stalled about 3 months ago because of a bad distributor cap so I took it to the mechanic and they replaced the distributor cap, rotator, spark plugs and wires. The problem now is that I noticed the decreased miles per gallon/increase gas consumption.
Do you think the problem I had with the distributor cap has something to do with the high fuel consumption that I have now?
I replaced the air filter today and I will see iit that changes anything. I also I checked the pressure in the tires and it is normal.
Any sugestions on how i can fix this problem?
Thank you.
Old Apr 2, 2010 | 10:00 AM
mike 02's Avatar
Default MazdaSilva
I would say they didn't adjust the timming right when the installed the new distributor.
Old Apr 2, 2010 | 12:27 PM
keninn's Avatar
what he^ said
Old Apr 2, 2010 | 02:22 PM
jbracefan1977's Avatar
Do you think the problem I had with the distributor cap seo has something to do with the high fuel consumption that I have now?
Thank you.
check your timing a spark plug gab for correct settings, simple and cheap fix you can do it yoruself
Old Apr 2, 2010 | 05:13 PM
keninn's Avatar
that's not quite true. you first have to put the car in diagnostic mode, which involves jumping a couple of pins in the diagnostic connector. and, since i dont have a 2.5, i dont know which ones they is. then you set the timing.
Spetz
Feb 16, 2009 05:17 AM
wimalhapu1
May 5, 2007 09:19 AM
raven82
Dec 6, 2006 08:42 AM
bigzoom
May 26, 2006 01:12 PM
extratorrential
Feb 14, 2006 10:53 PM
