effin' horn...
Old Aug 12, 2007 | 07:28 PM
ATon10's Avatar
Default effin' horn...
So my horn doesnt work anymore... I replaced the fuse under the hood, figuring it might be a simple problem such as that, but to no avail. it wasn't the problem. It's getting power to the relay because I hear a clicking noise from somewhere around the fuse box, so I assumed the horn had just broken...
So, does anyone know where the horn is located in a 99' 2.3L supercharged? I'd like to just replace it myself. Any help would be appreciated. [>:]
Old Aug 12, 2007 | 07:38 PM
keninn's Avatar
Default RE: effin' horn...
actually, there are 2 horns. basically, they are under each headlite. i had to remove the headlite to get at them. iirc, i have replaced 2 of them.
Old Aug 13, 2007 | 04:59 PM
ATon10's Avatar
Thank you for your help... I'll see what I can do with 'em.
Old Sep 25, 2007 | 05:00 PM
WoolleyJ's Avatar
Any pointers on removing the headlights? I see my broken horn down there below it, but I am leery of unclipping/unscrewing too much stuff. I have a 94 Protege. Thanks for any advice there!
Old Nov 3, 2008 | 11:05 AM
ATon10's Avatar
Yeah, so I popped off the tow-hook panel on the lower passenger side of the front bumper, and it was only then that I could actually see the horn. I removed the headlight and bracket, but even then, I couldn't get to it without removing the whole front bumper. But I was able to detach the horn from the chassis, and run the wiring up through the front of the engine. So I ended up mounting a new bracket to the engine bay and just grounding it to the frame I mounted it on. Sounds awfully funny, but atleast it passed inspection.
Thanks to everyone for their help.
Oh and by the way, I found NO logical way to even FIND the horn on the drivers' side... That's a WHOLE different story. But thanks!
Alucard
Jul 23, 2006 12:47 AM
98mazda
Jun 23, 2006 02:48 AM
Spunky
Apr 20, 2006 11:59 AM
ripcbx
Jan 1, 2006 02:38 PM
MiataLover
Aug 20, 2005 03:42 PM
