draining the radiator
Old Jun 29, 2010 | 12:54 AM
boattrash9's Avatar
Default draining the radiator
Hello,
I know this is prob a stuipid question but I am trying to drain the coolant out of m ymazda millenia. Well according to the manual the location of the plug is on the passenger side. Well there is a strange brass plug or cap there, anyone see this?? If so how do I get that one off?? I tried with a pair of needle nose to kinda wiggle it around but I didn't want to break anything without asking first.
Ok early thanks to all!!!
Old Jun 29, 2010 | 07:11 AM
keninn's Avatar
Originally Posted by boattrash9
Hello,
since the radiator for both 2.5 and 2.3 is the same, IF your radiator is a factory original, the drain is on the passenger side, only accessible thru a small hole in the lower front splash shield. you will need a large phillips head screwdriver, and unless you want coolant in the face, you will have to do it by feel. or, you can pull the splash shield, and then you will see it. some aftermarket radiators dont even have a drain
bvolks
Oct 13, 2012 08:59 AM
PatIRWIN
Dec 19, 2010 11:13 PM
g60swappedgti
Jun 11, 2008 10:13 AM
AmberRocks
Oct 13, 2006 11:06 PM
mydogduster
Oct 19, 2005 12:00 AM
