95 millenia s starts then stalls p1364code
Old Nov 14, 2011 | 05:48 PM
plumcrazy95millenia's Avatar
Default 95 millenia s starts then stalls p1364code
yes ive got a 95 millenia s that i bought as a non runner and have replaced everthing that was not to spec by the service manual.well now the car will start just as quick as u hit the switch and thats were the trickery starts.it will start and run for about 5secs and shut off just like its running out of fuel or turning off the switch.if u ever hit the gas it shuts right off.At that point it gives me a p1364 COIL PRIMARY CURCUIT MALFUCTION but wouldnt it at least run and have a skip?the fuel pressure regulator is about the only thing i havent replaced.the coils and wiring looked to be in good condtion not burnt or and frayed wiring.if anyone could help me i would be very greatful my hair would also cause this cars making it thin very quickly.Thanks,Jc
Old Nov 18, 2011 | 04:35 PM
tanprotege's Avatar
If you google for the code than you find that bad coils, wiring and connectors are common causes.
Since it is not misfiring but shutting off, I think it is in the coil or in the wiring to the coil or in the wiring/connection to the ECM.
brandynmarie
Aug 25, 2008 08:36 AM
johnnyzoom
Dec 29, 2007 07:00 PM
CaptainBob
Oct 22, 2007 05:18 PM
gblvdgirl
Apr 15, 2007 09:55 PM
04maz6
Apr 30, 2006 01:08 PM
