2002 Milly S Oil Leak somewhere above Oil Filter
Old Oct 26, 2009 | 09:13 PM
keninn's Avatar
Originally Posted by rockoe
i have the 96 millineum s. going on 2 years. love this car but that oil leak coming off the filter is what ive been chasing for about a year.im positive its not the oil filter or sending unit.my oil cooler line started leaking so i thought it was softning up old oil and making it look like oil.i cleaned it all good and still have that annoying little leak.how do you get the oil cooler housing off to change the o ring?that HAS to be it.im new here and this forum has saved me big money.thanks all.hope some of my findings will help someone as well.
remove the oil filter. you will see a large nut. that nut holds the oil cooler on. CAUTION:if you overtorque that nut, you will crush the cooler, and oil and coolant will mix, destroying your engine.
Old Oct 27, 2009 | 07:15 AM
rockoe's Avatar
Default Millenia, not millineum
Thanks for the caution.Any idea what the torque spec is on that nut? Just a nice tight snug on the o ring? Will i need to remove the coolant lines or is there enough clearance to pull it down and change the o ring?
Old Oct 27, 2009 | 11:05 AM
keninn's Avatar
fsm says 19-25 ft/lb. i would red loctite it, too. those hoses are pretty stiff, i take them off. actually, i get new ones. if i do this job, i pull the oil filter head, and do it on the bench. but, to do that, i go in from up top, and a lot of stuff then has to come off. plus, you will have to clean the gasket to the block, if you dont get a good seal, it will **** oil all over the place, and you get to do it all over again. even on a lift, and going from below, it is tight.
Old Oct 28, 2009 | 07:37 PM
JJohnsonAZ's Avatar
Default used ramps and got to it from underneath
I rolled her up on ramps...
I could see the top of the oil cooler from looking down but didn't try going at it that way.
I removed the two hoses for coolent...have a bucket ready. Then removed the filter.
Here is where I meesed up but learned from it...I removed the entire unit from the block. There are (3) 10 or 12mm bolts holding it on and you can only really see part of one. You have to feel around for it, and use extentions and a universal joint would have been useful.
Anyway, once that was all removed, I took the nut holding the filter adapter (I think Keninn calls it the oil filter head) off and there was the seal. Had I known what I was doing ahead of time, I would have just removed the filter adapter (head) first but its done now. I can't remember the size of the nut but it was larger than I had...had to borrow from a neighbor.
If you take the whole unit off, it is a pain in the **** moving the gasket. It is very tight up in there and I would guess it took about an hour to take off the small gasket plus it was a special order part. I ended driving to phx from Tucson...well, read the earlier post.
Then it is putting it all back together. I am not going to comment on any leaks now because there isn't any wood handy to knock on, but lets just say I am happy so far.
Thats it...have fun.
Old Apr 8, 2011 | 03:07 PM
santa6's Avatar
Originally Posted by JJohnsonAZ
Okay, Keninn you got me headed in the right direction.
The leak was from the "O" ring in the oil cooler. It would have been a very very simple fix but...I didn't know what I was doing so I removed not only the oil filter adapter, but the entire unit from the block (3 hard to reach bolts). That required an additional hour to remove the gasket that was stuck on the block, and then tracking down the seal and gasket. Tucson is too small and our local Mazda dealership is a joke. I ended up driving to Phx. today to pick up the in-stock parts from Berge Mazda...great folks there.
It is back together and the new juices go in tomorrow am...hopefully no leaks.
Thanks Keninn again for your assistance. I now know where the oil pressure switch is and what it will take to change that if it starts leaking. I most probably should've changed that while I had it out but it was perfectly dry. Oh well...learn as I go but a lot cheaper than taking it in.
Later.
Keninn, me again. Car is running great as I reported yesterday, but we also have a pretty quick oil leak from above the filter. I have jacked the car up and cleaned up the area. When my son starts the car I put an extension mirror up from underneath and can clearly see the oil seep out at the diameter of the body that the filter screws onto. It has a rubber hose connected to it. Is that a cooler?
If so, what is the best way to access and remove - I suspect it is a cooler or adapter of some sort and probably has an O-ring or gasket that is leaking.
Thanks
Old Apr 8, 2011 | 03:17 PM
santa6's Avatar
Keninn - a related question. I have looked all over for a good shop manual for the 2000 Millenia S and can't find one. Any ideas on where to get one?
Old Apr 8, 2011 | 05:08 PM
keninn's Avatar
if you have a 2.3, then it will be and oil cooler/heater sandwiched between the oil filter and the oil filter head. there is a large o ring that seals the cooler to the filter head. if you remove the oil filter, you will see the nut holding it together. you can get the manuals from the dealer, or check ebay
Old Apr 9, 2011 | 02:38 PM
santa6's Avatar
We're trying to measure this nut - can't get verniers all the way in but best guess looks like it is a 30mm nut. We have a 30mm deep socket but it won't fit into the cooler opening around the nut. Does this require a special socket?
Old Apr 9, 2011 | 07:18 PM
keninn's Avatar
iirc, i used a 30 deep socket that i had ground down to pull the rear flange nut off early bmw manual transmissions. 6 pt. it fit perfect. i had removed about half the outside metal on a lathe
Jessev
Aug 6, 2021 10:03 AM
m3rock
Jun 2, 2015 12:10 AM
dbirch2
Feb 20, 2009 05:37 PM
$96mill
Apr 12, 2006 12:01 AM
old929guy
Oct 13, 2005 01:13 AM
