starting problems
Old Mar 27, 2007 | 05:13 PM
john wells's Avatar
Default starting problems
have been unable to start my car. on turning over it sounds as if the starter motor is engaged all ready. have tried rocking the car in gear to disengage but with no joy. Have started to remove the starter motor but it is not the easiest thing to do . Any one any advice to make it easier or if they have had a problem with the starter motor
Old Mar 27, 2007 | 09:16 PM
CHR's Avatar
CHR
Default RE: starting problems
It could possibly be your spark plugs and/or spark plug wires. The current is not strong enough to spark the fuel. Your fuel pump might be out. Your fuel lines might be clogged. You possibly might need to change your timing chain.
Old Mar 28, 2007 | 05:54 AM
john wells's Avatar
Thanks...
Fuel, spark and timing belt are all fine. got to try and boost the battery to have another go to rule that out but definately sounds like the starter motor
freeflyur2
May 25, 2006 04:50 PM
waveslider2007
May 15, 2006 11:34 AM
redpeppers
Mar 25, 2006 03:08 PM
michael929
Feb 27, 2006 03:57 PM
Tom73
Nov 18, 2005 04:44 PM
