MX-5 NC turbo kit
Old May 6, 2011 | 12:25 PM
rtlowell's Avatar
Default MX-5 NC turbo kit
I just inherited an after-market turbo-charger from my son's Mazdespeed Miata (he's going back to the stock turbo). I have a 2006 2.0 NC that could use a boost. where would I go to get the neccessary bits to graft this set-up together?
Old May 6, 2011 | 08:58 PM
wsoape281's Avatar
it depends on the options that you want. the options are endless here. bottom line is that you are going to be on your own as far as parts. there aren't a lot of NC turbo parts out there unless you buy a complete kit.
i always recommend going with a cast iron manifold on anything that isn't a show car. i wouldn't really know where to find one though. a local custom shop should be able to cut and weld you a down pipe and manifold without a problem. it will be tubular though. low boost applications should be easy to cool. a custom intercooler would be a good idea here if you have some fabrication skills. if not, you can spend the bigger money on a pre-built intercooler set-up. local custom shop should be able to handle that. i have a few recommendations in the links below.
Flyin' Miata : NC MX-5 : : FM ECU reflash by Dynotronics
Air to Water Intercooler
Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts
other than those, you need to rely on local experts.
bluemazdaprtege
Jul 2, 2010 05:01 PM
the_gray_mazda6
May 20, 2006 01:03 PM
mario
Feb 17, 2006 10:48 AM
slowingsleeper
Aug 29, 2005 10:19 PM
Minimonster
Feb 21, 2005 03:00 AM
