Left Turn Signal
91, left turn signals do not light. Though I hear the blinker switch clicking fast, bulbs are olay. Right signals are fine. Hazard lights only work on right side of vehicle. Indicator light in the dash olny blinks on the right. Any ideas?
WHEN TURN SIGNAL CLICK VERY FAST IT USUALLY MEANS THAT CIRCUIT RESISTANCE IS LOW. USE A TEST LIGHT CHECK TO SEE IF POWER IS
GETTING TO BOTH LEFT SIDE LIGHT BULBS. THESE WIRES ARE GREEN WITH ANOTHER COLOR TRACER. IF NO POWER THE FLASHER COULD HAVE
INTERNAL PROBLEM OR THE CIRCUIT IS SHORT TO A GROUND. CORRODED LIGHT SOCKETS OR CONNECTORS CAN BE THE PROBLEM.
TRY THIS LOCATE THE FLASHER, DRIVER'S SIDE ABOVE PEDALS, HAVE TURN SIGNAL ON, FIND THE ONE MAKING NOISE. DISCONNECT AND RECONNECT
THE WIRE HARNESS TO THE FLASHER, IT HAS WORKED FOR ME ON THREE VEHICLES. DOUBLE CHECK THE LEFT LIGHT BULBS, PUT POWER AND GROUND
TO INSURE THERE DO WORK, HAVE HAD BULBS WHICH LOOKED GOOD BUT ARE SHORTED INTERNALLY.
