I need to install a radiator
Old Sep 30, 2007 | 05:18 PM
confuZion3's Avatar
Default I need to install a radiator
Has anyone here installed a radiator before in their miata? Mine is a 1994 and the radiator is definitely leaking. The leak is at the top on the passenger side and it appears as if the unit needs to be replaced. I just wanted to know if there is anything that I'm going to need to look out for when tackling this job. I'm pretty sure it's going to be a straight-forward job, but there's always a catch.
Thanks!
Old Oct 14, 2007 | 10:59 PM
highsider's Avatar
Default RE: I need to install a radiator
confuZion3,
Your right, it's a simple job. Plenty of room to work after the intake plumbing and stuff are out of the way. Your main choice is whether to use the Mazda replacement radiator or get a more reasonably priced one thru your local radiator shop. I opted for a copper core one, that is slightly heavier than the plastic tanked aluminum core original. Good oppertunity to check out the functioning of your electric fans if you've noticed any heating up at low speeds or idle also. mine's a '95 good luck
MikeAvila
Oct 14, 2010 12:47 PM
Runerider
Jun 14, 2009 02:10 PM
MazdaSilva
Jun 22, 2007 10:19 PM
turbo_miata20
Jul 8, 2006 08:57 PM
thomas1960
Jul 3, 2006 07:58 PM
