Heater on mark 4 MX5 not getting very warm
Old Oct 23, 2023 | 02:05 PM
MARY_UK's Avatar
Default Heater on mark 4 MX5 not getting very warm
Hello. My name is Mary and I have a 2015 mark 4 Mazda Mx-5. Mileage = 23,800. It takes a drive of about 6 miles before I get the mild 'warm' heat through to my heater. After a run of about 20 miles my mild warm heater stays at the same temperature, mildly warm but certainly never hot despite the temperature and fan being set to maximum. I took it to a local mechanic/diagnostic centre who recommended a genuine thermostat and heater matrix flush. My regular mechanic had already checked the coolant and for any leaks. Despite these efforts, the problem still persists. Have any members out there had the same experience and how did you have the fault rectified please? Thanks.
Old Oct 31, 2023 | 12:37 PM
Dino1956's Avatar
Unusual. And you have it all the way to hot with the fan on high? I have a 2008 Grand Touring with seat warmers. My heat is super hot, so much so, I have to turn it off at times even on the lowest setting. Hopefully someone more knowledgeable on your issue will chime. in.
Old Oct 31, 2023 | 04:00 PM
MARY_UK's Avatar
It does seem to be unusual and yes the fan is on high and the heater on the hottest setting.
Old Nov 5, 2023 | 03:07 AM
I would use a infrared temperature gun to check the temperature of both the heater pipes under the dash and compare them to the rest of the cooling system under the bonnet.
Old Nov 8, 2023 | 03:21 PM
MARY_UK's Avatar
Thank you grim_reaper for your advice. I'm going to take the car to the main dealer nearest to where I live. I will discuss the way forward with the technicians, remembering your suggestion. If anyone else out there has any further advice I would be most grateful to hear from you. Much appreciated. Mary
newbie3
Oct 14, 2014 01:55 AM
gnetrok
Jul 21, 2011 04:17 AM
driftwood1
Oct 11, 2010 01:10 PM
golfamigo
Apr 10, 2008 08:48 PM
theneedforspeed
Jun 5, 2007 07:50 PM
