Air Bag Control Module Diagnostic Help
Old Mar 8, 2008 | 12:09 PM
1jzZee's Avatar
Default Air Bag Control Module Diagnostic Help
On my '91 miata, the air bag light shows a code '10' which I know is the fuse inside the control module (right?). I replaced the module with a used part about 4 years ago, after the same code was present, and the system has been fine until the same code came back recently.
So my question is, does anyone have access to an online '91 repair manual that will help me diagnose the real problem (if there is one) before I replace the module again? I read here that I should check the resistance(i think?) between the sensor plugs, with the battery disconnected and the air bag and air bag control module also unplugged, to make sure there is not a short in the wiring that is causing my problem in the first place. The repair manual I have just says to take the car to the dealer.
Also, is this the least expensive place to find the module? And is this the correct part? (called a diagnostic unit) http://www.trademotion.com/partlocat...layCatalogid=0
Thanks!
Old Apr 13, 2008 | 01:35 PM
1jzZee's Avatar
Default RE: Air Bag Control Module Diagnostic Help
can anybody give some input??
thanks
Old May 5, 2008 | 04:58 PM
1jzZee's Avatar
I have a new module, but I still need help diagnosing the car to make sure it won't blow the fuse again. What do I need to check?
Code 10, air bag control module.
Any suggestions??
Pretty1842
Oct 7, 2012 06:21 PM
savior
Jan 30, 2011 01:58 PM
scw1220
Nov 10, 2007 07:45 PM
casterman
Sep 17, 2007 09:44 PM
MazdaES
Jul 5, 2007 09:25 PM
