Mazda Forum Help & Suggestion Center Forum for members experiencing problems with the board or those who have suggestions to make the forum better.
Mazda Demio Seatbelt Replacement
Old May 15, 2020 | 05:38 AM
JamiePatt's Avatar
Default Mazda Demio Seatbelt Replacement
Someone might be able to help with this. I’m trying to replace the seatbelt in a 1997 Demio that had a frayed belt. I removed the belt from a donor car, which was working fine, but after I go to install the mechanism appears to have locked. I’ve removed the frayed belt and the same thing appears to have happened on that belt. It’s as if once the mechanism is no longer under tension it locks up. Is there a way to release it again so it can be installed?
Old May 16, 2020 | 03:53 AM
Seatbelts are super sensitive to the angle they are at, a couple of degrees forwards/ backwards, side to side will lock or unlock the retractor mechanism.
Wrenchy
May 4, 2016 12:11 AM
kiko
Dec 13, 2012 03:35 PM
Phaeton02
Sep 1, 2008 05:25 PM
Sportfly
Jan 24, 2008 11:00 PM
Gerry
Apr 27, 2006 06:42 PM
