What are brakes supposed to feel like?
Just installed new rear rotors and brake pads on my 2014 CX-9 (fwd). I was told by a local shop afterwards that they think the brake pedal now feels a bit softer than it should. My wife and I don’t notice anything different. I then bled all brakes at the four calipers starting from the right rear and working forward to the driver’s front side. No bubbles or air. Fluid is a urine color yellow. The pedal still feels the same and we don’t notice anything different from the way it was before the new brakes were put on. Should I be concerned?
Question: Does the 2014 CX-9, or any CX-9 year for that matter, have a softer pedal than most vehicles out there? Not super firm? In other words should it take a bit more foot pressure on the pedal (maybe down halfway) to engage the brakes? When I slam down on the pedal, of course the vehicle stops immediately but the pedal is not at the floor.
Thanks!
Thanks!
You are asking a subjective question? If they feel the same before and after your brake service, then likely that is correct.
If you have a question as to the safety and proper function of your brakes, then have the brake system inspected by a service change like Firestone.
Wherever you go let them inspect it without telling them you just serviced the work and see what they say?
Good to know. Is this something any qualified shop can do? Sounds like it’s adjusted through the computer then, correct? Using the scan tool. Should I expect this to cost a good deal? Thank you!
Most qualified shops and any shop I would say that has an ASE blue sign at least one of their employees will have a certification to perform the brake bleed and has a professional scan tool. It would be billed at 1 hour so the cost can vary. Seems you only put USA in your signature info I cant give you the estimated shop rates in your state, county and city. In my shop it would be $150.00 plus fluid.
