Transmission Flush - 2012 CX9
Old Mar 4, 2022 | 05:56 PM
chasfish's Avatar
Default Transmission Flush - 2012 CX9
When you do a trans. flush, should all or almost all the fluid be changed out? I just found out today that my recent trans. flush only removed maybe 6 of the 7 quarts of fluid in my 2012 CX9. Does that ring true, or should they have flushed out and replaced essentially all of the fluid?
thanks
chuck
reading, pa
Old Mar 26, 2022 | 02:28 PM
winkybil's Avatar
I have a 2012 CX-9 as well. I have that issue now and again. Ours has 135k+ on it and drives perfectly otherwise.
Old Sep 26, 2024 | 04:09 PM
winkybil's Avatar
I found that when it shifts hard like that I sit in neutral for a few seconds and it seems to go smoother. I live in an area with a lot of hills and had to get the emergency brake serviced a few times. I believe that contributed to it as well.
Old Sep 27, 2024 | 12:11 AM
based on that description you are at a stage of transmission problems that have been building for some time from lack of basic service. My advise to do a simple pan fluid and filter service ASAP so you can physically see what’s in the pan, how much varnish build up you have a better idea by what the pan magnet caught.
juzandbec
Jan 28, 2024 01:29 PM
chasfish
Feb 27, 2022 02:06 PM
chasfish
Feb 22, 2022 04:46 PM
chasfish
Jun 9, 2021 09:03 AM
Mbciuso
Apr 12, 2016 03:36 AM
