How to remove rear differential drain bolt?
Old Sep 3, 2022 | 06:56 PM
tknaste's Avatar
Default How to remove rear differential drain bolt?
Hi, so I watched a video on draining rear diff And they used a socket for both drain and fill bolts. Looked easy enough so I go buy the supplies, get the car up on jack stands, get under there and there is a cross member in the way and not enough room to get the ratchet and socket on the drain bolt. Do I need to use a box wrench for that or am I missing something? Now I remember why I stopped working on my cars for the last few years!!!!
Thanks
Old Sep 4, 2022 | 06:52 PM
PTguy's Avatar
When you find the way to drain the oil, first loosen the fill plug. If you can't loosen the fill, don't drain the oil out.
Old Sep 4, 2022 | 07:00 PM
tknaste's Avatar
I am going to try a 23mm combination wrench but have to order one because nobody in my area has one. I am just confused because the videos I have watched are using a socket for both fill and drain bolts. Hopefully it will work and I will post a picture. Thanks for the advice on making sure to loosen the fill bolt first.
tknaste
Sep 3, 2022 02:05 PM
Simon Gilmour
May 20, 2018 05:47 AM
Micaela Nicole De Leon-Munoz
Feb 11, 2018 07:21 AM
Dave Lister
Mar 16, 2017 02:53 PM
stoveguy
Oct 3, 2009 08:29 PM
