Horn fuse keeps blowing
Old Aug 28, 2016 | 02:16 PM
swolk99's Avatar
Default Horn fuse keeps blowing
Hi, I have a 2010 CX-9. Last night I discovered my horn is not working. I checked the fuse and it was bad. I replaced it with another 15A fuse, it it blew right away. Does this mean there is a short somewhere? Could the horn relay be bad?
Might be related, but when we get a really heavy rain or go through the car wash, the alarm/horn will start going off seemingly randomly, like some water got in somewhere. After a while it clears up. But, I havn't washed the vehicle and we haven't got any rain recently. I had seen an issue with CX-9 with moon roofs having issue with drain clog causing water to penetrate BCM. My vehicle doesn't have moon roof so don't think there is an issue there.
Thanks,
Scott
Old Aug 28, 2016 | 09:33 PM
swolk99's Avatar
follow-up:
I picked the high horn and disconnected it. When I tried to honk the horn, still no sound but the fuse did not blow. Connected the horn, then when tried to honk the horn, fuse blew.
Two follow-up questions:
1) Does it make sense that the low horn doesn't make a sound when high horn is disconnected?
2) Do I need to just replace the high horn?
Thanks,
Scott
Old Aug 29, 2016 | 03:23 AM
You need to check the wiring to both horns & bench test the two horns.
John taylor
Jul 31, 2010 03:52 AM
bigred2600i
Nov 11, 2009 10:25 AM
Q187
Jul 31, 2007 08:07 PM
Lawbreaker
Jul 10, 2007 11:30 PM
bs24
Jan 6, 2007 06:43 PM
