Door Not locking
Old Nov 27, 2017 | 06:08 AM
the_desperado's Avatar
Default Door Not locking
I noticed today that the front passenger door on my CX9 2011 does not lock at all. I don't know since how long the issue is there but I cannot lock it with the smart key, the door button or even locking it manually from inside. It sill can be opened from outside without the key.
I noticed as well that the door-lock **** does not move when I lock or unlock. it is always stuck on lock position.
What do you think is the issue and is it an easy fix?
Old Nov 28, 2017 | 10:11 AM
JeffMD's Avatar
Easy fix? technically yes.. but it still requires pulling off the molding and investigating the linkage between the locking control bar and the doors latch mechanism. If you can't manually lock it then there is an issue around that point.
Old Sep 5, 2019 | 06:28 PM
Alberto Duran's Avatar
I am having this very same issue, have you found a fix??
Old Sep 8, 2019 | 10:43 AM
gmaddox's Avatar
There is a rod that connects the inside mechanism to the side rotating piece that locks the door. There are plastic clips that the rod moves through. If the clip is broken or the rod is outside the clips, then it can not engage the lock.
You will need to pull the door panel to find out. A reputable shop can probably correct this for no more than an hours labor.
Old Sep 14, 2019 | 11:55 AM
Thanks gmaddox, that was exactly my problem, the rod was out of the clips. I was able to do it myself, took me about 10 minutes!!
Zaxx81
Aug 2, 2022 07:44 PM
jon5bellies
Jul 14, 2012 03:08 PM
jb0415
Jun 6, 2012 04:08 PM
alfy
Aug 11, 2010 05:04 PM
Hookematx
Sep 15, 2008 07:08 PM
