Delete ac compressor
Old Sep 1, 2021 | 05:08 PM
tsizzle55's Avatar
Default Delete ac compressor
Ac compressor is bad and the repair shop wants $1000 to fix see if u can skip the compressor and run a belt from the crank to the alternator and what size belt to use plz help I have a 2011 cx9
Old Sep 2, 2021 | 11:25 AM
Bronco Boy's Avatar
Originally Posted by tsizzle55
.....can skip the compressor and run a belt from the crank to the alternator
You would need to remove the compressor and install an idler or tensioner. Custom work, but could be done.
Old Sep 4, 2021 | 05:24 PM
PTguy's Avatar
Why not leave it there? If the electric clutch is OK, just let the clutch spin uselessly. Perhaps disconnect a wire from the compressor's clutch. Even if the clutch is no good and can't disengage, replacing the clutch probably costs less than the custom work described above.
Bob Lepore
Apr 13, 2021 01:13 AM
dbelcourt
Aug 20, 2020 11:55 AM
MAZDEER
Apr 10, 2013 10:00 PM
danrhem1
Sep 5, 2011 12:24 AM
meta4
Jul 17, 2006 10:54 PM
