3 AC compressor stopped working
Old Jul 27, 2019 | 04:46 PM
Bob Lepore's Avatar
Default 3 AC compressor stopped working
MY 2009 Mazda3 AC suddenly stopped working. Can't get compressor to kick on to check coolant. ANy suggestions
Old Apr 13, 2021 | 01:13 AM
ImJynxed's Avatar
Check related fuses and wiring and replace if necessary. If good see about testing compressor connection to ground, continuity and ohm measurements if possible. If compressor burnout occurs u need to completely purge the system with nitrogen before installing a new compressor as well as replace filter driers and check txv's to ensure properly functioning. Most burnouts occur due to sludging of system oil (ac not engine oil) which deteriorates the coating on wire within the compressor housing which will contaminate refrigerant and oil in the ac system
And make sure not to release refrigerant into atmosphere and gauge amount when recharging to manufacturer specs
dbelcourt
Aug 20, 2020 11:55 AM
Budgy
Mar 26, 2020 06:29 PM
MAZDEER
Apr 10, 2013 10:00 PM
danrhem1
Sep 5, 2011 12:24 AM
meta4
Jul 17, 2006 10:54 PM
