Center (3rd) Brake Light 2012 Mazda CX 9
Old Oct 29, 2019 | 08:19 PM
danpeters08's Avatar
Default Center (3rd) Brake Light 2012 Mazda CX 9
Center brake light (3rd brake light) on my 2012 Mazda CX 9 will not light. (1) Possible causes? (2) To hotwire another light - where do I find the hot wire in the bundle to put in a new (and separate) light? (Wire Color) I'm not paying $120 U.S. for a new LED light. Many thanks.
Old Nov 1, 2019 | 03:03 AM
Kami's Avatar
LED light don't go out that fast. Your issue is wiring related. Open the back up and follow the wires until you found the part that is striped. It usually done by Rats. Those critters like to chew wires.
Good Luck!!!
Old Nov 1, 2019 | 10:58 AM
Smile 3rd Brake Light - Mazda 2012 CX 9
Got that right - LOL! Pesky critters. Turned out it was a faulty or insufficient ground from the lights to the chasis. My quick fix was to grab the return wire with an alligator clamp - likely a ground wire coming out of the lights - and attach it to the tail gate with the other alligator clamp end. Put the plastic back on over it - and it worked - passed state inspection. I should likley more permanently attach it?!
Old Feb 10, 2023 | 11:51 AM
MonkeyMD's Avatar
Where is the grind wire from the lights.
Just replaced the brake light & still not working
Old Feb 10, 2023 | 12:35 PM
Monkey Welcome to the forum
Are all assuming you have the same Mazda model and year as the one in this thread. If not I recommend to start your own thread?
Old Feb 10, 2023 | 01:03 PM
MonkeyMD's Avatar
Yep. 2012 CX9
Old Feb 10, 2023 | 01:15 PM
Originally Posted by MonkeyMD
Yep. 2012 CX9
So your problem is your own and again I suggest you start your own thread.
On forums normally you don't start asking question in an old thread about your own problems.
But to answer you on now 2 threads you are responding and posting in...
The proper test next should be test the connector. To do that you will need a simple Volt or volt/ohm meter.
Old Feb 10, 2023 | 02:30 PM
MonkeyMD's Avatar
I've been on a few forums & consensus is never start a new thread if you are having the same issue to keep things organized, but noted for this forum.
I'll have to get a multimeter to test connection I guess.
Thanks.
Old Feb 10, 2023 | 02:41 PM
Thanks.
You can always do what you want? Its just a little common sense about threads and also polite when its not your thread!
Most forums are the same way and a good moderator would remove your post and create a thread for you.
Your first question was to ask where the ground wire is? I can't even begin to go into why that would be down the list of first questions asked regarding a light that wont activate.
But as for your problem you need to do the basic problem shooting checks so "I guess" you will need a volt meter! If you are working on any vehicle that is an inexpensive and VITAL tool to have. Electrical problems are not guess work and are easy to solve with the correct steps and tools. With out them you could easily dame more electrical parts by hit and miss guessing what a solution is. Lecture done! LOL
CX5gal
Jun 6, 2021 06:19 AM
Chris Smith
Jan 30, 2019 12:52 AM
Francis1371
Feb 17, 2015 09:04 PM
fluxcapacitor01
Sep 12, 2011 02:53 PM
