I need to remove the side Cargo/3rd row seating area to access the 2nd row seating. I am aware of the need to disconnect battery before removal of seat belt return assembly.
What I cannot find is a direction or video related information for removal of the passenger side panel. I can remove the covers circled yellow and remove the screws behind these covers. I can easily remove the weather seal along the panel and door.
What I do not know is how to remove the attachment point circled red for a child car seat? Also how to release the panel to access view of the seat belt mechanism. Assume within region of the white dashed lines.
I can yank on the seat belt and get no response or movement. Has about 7 inches of slack in belt. Not enough to reach buckle and click and use as seat belt.
This is a real pain if you have two large adults needing to sit in the 2nd row. Please advise. Thx!
Not 100% certain why the mechanism locked. But want to say THANK YOU!
Your link provided the needed details to remove the side panel and manually turn the recoil backward 1 turn. Then when pulled to extract belt it started to work fine.
Tried several times and pulled out and retacted as should.
THX again. KJJ
