2014 CX9 Low beam lights quit simultaneously - Help please!
Old Jun 15, 2020 | 05:28 PM
Ghostman's Avatar
Default 2014 CX9 Low beam lights quit simultaneously - Help please!
Hello There:
We recently returned from a long drive and the low beam headlights stopped working. Since we had changed the bulbs about 6 months ago and the low-beams stopped functioning at the exact same time, we are thinking it not just as simple as bad Sylvania bulbs. The parking lights and brights function just fine. The first thing I did was replace the headlight relay in the relay box under the hood with no luck. Thinking now it may be the ballast, though the bulbs are not HID which usually impacts the ballast life. Has anyone encountered this issue and come up with the recipe to fix. Appreciate any and all guidance or experiences to resolve.
Thanks for your help,
Ghostman
Old Jun 15, 2020 | 08:19 PM
Bronco Boy's Avatar
Halogen lights don't have a ballast. Check for power at the lights, at the relay and at the fuse (to start).
Old Jun 15, 2020 | 09:01 PM
Ghostman's Avatar
Default Thanks Bronco Boy
Appreciate your response. Sounds quite sensible.
Ghostman
Old Jun 16, 2020 | 11:39 AM
PTguy's Avatar
Or it could the in the switch. Do they share a ground connection? That is one more thing to check if it's common to both. (Check the grounds anyway...they need to be clean, dry, & tight.)
Old Jun 16, 2020 | 02:15 PM
Ghostman's Avatar
Will do PTguy and thanks much.
Ghostman
Gary U
Dec 23, 2019 03:43 AM
aerobat66
Oct 13, 2019 03:12 AM
MyRustyMazda
Feb 20, 2019 09:21 AM
timmy01
Dec 12, 2011 05:10 PM
Shaun323
Nov 14, 2008 04:38 PM
