2014 cx 9 hatch cargo light wiring
Old Jun 9, 2020 | 02:27 PM
Gasman6674's Avatar
Default 2014 cx 9 hatch cargo light wiring
Does anyone have access to the wiring diagram for the hatch?
I am trying to locate the switch that turns on the hatch mounted cargo light. I don't see or can't find any kind of plunger switch.
Is it in the latch? I have searched google and it was pretty useless.
Thanks
Old Jun 10, 2020 | 08:15 AM
The trigger / switch is built into the door latch assembly.
Old Jun 10, 2020 | 08:19 AM
Gasman6674's Avatar
That's what I figured. Do you think spraying it wit contact cleaner would help?
thanks
Old Jun 10, 2020 | 08:22 AM
What is the problem?
What diagnosis have you carried out?
Old Jun 10, 2020 | 08:27 AM
Gasman6674's Avatar
Cargo/hatch light will not come on in the "door" position. Known good bulb. Removed light and tested separately and it works. I even bought a new light (before I tested the old unit) and its dosent work. I'm not getting power so I figure trigger switch is bad/gummed up.
Old Jun 10, 2020 | 08:42 AM
I assume the switch has 3 positions, ON OFF & DOOR ?
What happens when set to ON?
Old Jun 10, 2020 | 08:45 AM
The switch should have 12v all the time, and will have a switched earth via the BCM for ON, or via the door position switch in the tailgate.
Old Jun 10, 2020 | 08:47 AM
Gasman6674's Avatar
No just off and door. I removed it and tested with 12 v sourde and it works. I tested connection with a volt meter and no power
Old Jun 10, 2020 | 08:50 AM
Gasman6674's Avatar
Ok will test it again with a separate ground. thanks for the tip
Old Jun 10, 2020 | 03:18 PM
Bronco Boy's Avatar
I recently put in an LED strip back there on my 2009. My right up may have some useful info....
LED_Tailgate
And attached is the wiring schematic.
File Type: pdf
