2008 CX9 runs rough and stalls
Old Jun 8, 2018 | 09:42 AM
Mike115500's Avatar
Default 2008 CX9 runs rough and stalls
Hi all,
I replaced the water pump (antifreeze got into the oil) in a 2008 CX9 by way of dropping the drivetrain. Used the ford cam lock tool. reinstalled and she ran good for 5 minutes on a test drive. Then it started cutting out and stalls. Starts back up but the same conditions existed. Put it a scanner and it came up with P0016, 2195 and 2197. Also my assistant had left a connector off at reassembly that I cant figure out where it goes. Its off the front emissions harness, about 18" long with a 1 pin connector.
Any recommendations would be greatly appreciated. I'm stumpped
Old Jun 10, 2018 | 06:24 AM
P0016: CKP-CMP sensor (RH) correlation
** DETECTION CONDITION
• The PCM monitors the variable valve timing position for a misalignment between the camshaft and crankshaft. The test fails when the misalignment is more than 1 tooth.
** POSSIBLE CAUSE
• OCV malfunction
• Camshaft advanced mechanism binding
• Improper valve timing
P2195: Front HO2S (RH) signal stuck lean
P2197: Front HO2S (LH) signal stuck lean
SLSB2200
Jun 5, 2021 08:52 AM
anjp
May 27, 2013 03:56 PM
jcr_iv
Jun 5, 2011 12:37 AM
dove
Apr 24, 2008 09:37 AM
akl
Jan 18, 2007 11:35 PM
