AFM CX70 Exhaust
Any aftermarket exhaust system (CAT back or rear section) that uses basically a loose material and not baffles or chambers will all have the same break-in period before the end sound can be judged.
Most aftermarket perfromance exhust compnies and suppiers generally will not stae thier interanl parts use unless you contact them diorect and then mabe? No one really once to know that those stainless steel nice looking exhaust parts have basically stainless or plain steel wool to reduce the sound levels. Ever take a match to wither of those materials?
Hey I have used and tried Racing Beat, OBX, and Cork sport on my Mazda. I prefer the OBX. but only becuase of personal choice and nothing having to do with quality or perfromance.
Dont take this wrong but having sold so many exahust system(mostly perfronace) and parts for decades , peky customers about what they expected the sound should be with some resonators and mufflers is why I never engineerd and dessign my own line of perfomance mufflers.
geeez ....
It does not nessisarly work like the question you want a deifintive answer. ! So that leads me to belive that you have little or no expernce with perfromance exhaust parts.
I cant find the actaul comany so there fore I can give you better information then a blankit statement of what tyo expect!!!
I don't need to have tried a muffler or resonator to know what it will sound like in the beginning and as it ages or use or miles of use.
Why dont you contact the retailer of the product you are interested in and ask them and see what they tell you? Then compare it to what I just spent time intrying to help you and expalin about perfroance mufflers and resinators
Sir I have contacted AFE. They say no drone but slightly louder sound. I wanted the response of someone who has actually installed this on a 2025 CX70 3.3 turbo. Yes I have many years experience with vehicle exhaust. I know what drone is. You haven’t said if you have this exhaust
I don't need as I said to use some products to know what they will sound like. however, I very well know the Skyactiv gas engine in all induction configuration and their factory exhaust to know how an aftermarket exhaust will sound.
Besides I just talked to 3 so called techs and they kept passing me along because only the 3rd one (the head of the Q&A tech department actually could answer simple questions. He offered me a job... as a phone tech. LOL
This was my summary not AFE's btw!
The muffler from AFE is a 4 chambered design. The system is a rear set only. It does not replace the factory mid-section and factory resonator. So the sound will be deep at idle speeds and low RPM but likely close to quiet like stock on highway at legal speed limits.
Chambered mufflers in rear section will not increase any performance levels and are more for look and that low engine speed sound than anything else. Because they are chambered muffler, they will not produce a drone when used as designed.
I should mention that the muffler itself does not use high quality stainless steel for the core and body so depending on the use environment may only last a 2-5 years before problems start internally or externally.
Good luck with your choice.
