Timing chain replacement question
Old Nov 28, 2014 | 04:21 PM
blackbalts's Avatar
Default Timing chain replacement question
Ok, so I just bought an 07 CX7 and the timing chain has a decent amount of slack and there is a slight tick while idling. I'm not concerned about the ticking (I believe it's the fuel pump/ or injectors), but the dealership says it's the timing chain and VVT. I ordered parts online that include the following as well as the alignment/ TDC kit. I'm guessing I might also need a tensioner, can anyone confirm what else is needed to do this replacement properly so I dont have to worry about it again? I would greatly appreciate it!
1 L3K9-12-4X0C-9U: Variable Valve Actuator
2 L3K9-12-429: Washers
1 LF01-11-406: Crank Shaft Pulley Lock Bolt
1 9XG0-99-667L: Blind Plug
1 L3K9-12-201A: Timing Chain
1 L3K9-10-230: Valve Cover Gasket
14 LFBL-10-237: Valve Cover Bolt/Grommet
1 L3G6-10-602: Oil Seal
3 L3H5-11-407: Lock Washers
1 0000-77-1217-ES: Silicone RTV
1 L3K9-10-193: RR Gasket
1 L3K9-13-ZE5: O Ring
Old Nov 28, 2014 | 06:04 PM
hixx's Avatar
Possibly guides/gears/tensioner.
Old Nov 28, 2014 | 10:40 PM
blackbalts's Avatar
Possibly? Is there issues with the intake cam gear? The kit comes with the VVT gear which is the one with the issue correct? I need to order before the end of the weekend so I can receive and install before next weekend. Thanks!
Old Nov 29, 2014 | 07:27 AM
hixx's Avatar
A lot of times a loose timing chain is caused in part by wear of the gears and not the chain stretching.
Old Nov 29, 2014 | 10:25 AM
blackbalts's Avatar
Fair enough. I was hoping to avoid spending the extra, but I'll buck up for the guides and tensioner. Thanks for your help.
Old Nov 30, 2014 | 02:16 AM
Do you have the plate to lock the two camshafts?
Do you have the front crank seal & Rockercover gasket?
ejciii216
Mar 4, 2023 12:10 PM
macguffin
Nov 17, 2008 03:08 PM
homeflash
Apr 4, 2008 11:55 AM
mpksguthrie
Sep 5, 2005 12:28 AM
