High idle on start up
Old Mar 27, 2020 | 04:26 AM
TommyPickles84's Avatar
Default High idle on start up
Hey guys, I’ve got a 2010 cx7 2.3L turbo, it idles at 2000 rpms for about 30 or so seconds on start up is that normal or should I be looking for a vacuum leak? My other cars might idle a little high on start up and take about the same time or less to calm down, but the 2000 seems higher than what I’ve ever been used to. Also I’ve never had a vehicle with a turbo before so I didn’t know if that would have anything to do with it
Thanks for any help!!
Old Mar 30, 2020 | 03:15 PM
luklyz's Avatar
This is normal for mazda 2.3 turbo. The engine revs at strat up to build up fuel pressure for direct injection.
There is no issue here.
Old Jan 8, 2022 | 05:21 AM
Evwill's Avatar
Default High idle start
Yeah it's normal but to me it seems brutal on a cold engine. When I start mine I put it straight into drive with my foot on the brake to slow revs under load. I haven't had an issue doing that on cold start for a few years now
Old Jul 28, 2022 | 04:35 PM
heggady's Avatar
I am having the same issue; but the problem I am having is that Check Engine light comes on after the cars first startup of the day.
The error says 4th cylinder misfire; but my mechanic and I move the spark plug & coil to another cylinder and we get the same error (P0304).
Any help solve this annoying issue, would be appreciated.
Old Jul 29, 2022 | 04:08 AM
Common problem with excessive build up on both valves and fuel injectors.
Old Aug 1, 2022 | 09:35 AM
heggady's Avatar
So what can I do?
Old Aug 2, 2022 | 07:24 AM
Originally Posted by heggady
So what can I do?
Remove the intake manifold, remove the fuel rail, clean the intake track & valves. Fit new injectors, refit manifold ( with new gasket)
Savannafc
Jan 6, 2016 12:21 PM
ptt
Mar 31, 2010 10:45 PM
Thor_k06
Aug 29, 2006 01:25 PM
isl_cruiser
Aug 8, 2006 12:56 AM
alfonso731
Mar 18, 2006 01:12 AM
