Any rear coil springs that fit, aftermarket?
Old May 12, 2023 | 03:36 PM
Enriquecx7's Avatar
Default Any rear coil springs that fit, aftermarket?
Looking for better REAR COIL SPRINGS
2011 MAZDA CX7 SV
ADVANCE AUTO SAYS THEY HAVE MOGG SPRINGS THAT FIT, ANY ONE HAS TRIED THEM?
ANY AFTERMARKET, DOES CX9 SAME YEAR WILL FIT?
THANKS
Old May 12, 2023 | 04:48 PM
Welcome to the forum,
MOOG is one of the top suspension aftermarket companies with a reputation dating back to the 60"s.
If you are looking for a stock replacement MOOG is a good choice.
I was a MOOG Distibutor/retailer and wholesaler ion my shops at one time.
The top brands were TRW and MOOG for OE suspension parts.
Old May 12, 2023 | 06:42 PM
Enriquecx7's Avatar
Thanks, but one of the reasons im looking for advice is that Mogg . Com page doesnt have rear springs for my cx7 2011, but at the Advance Auto parts site it does. The same part number at Mogg . Com is for a mazda cx9... Any compatability?
Old May 13, 2023 | 09:02 AM
You can either do the easy route and contact them
OR
Go to the spring specification and do a little work to check the spring specification.
Often times there are other parts that will fit but are not applicated because of OE requirement need to be met to call them an OEM replacement parts offered aftermarket.
Old May 13, 2023 | 11:31 AM
Enriquecx7's Avatar
Default Parts that fit
OR
I had that idea but mazda oem catalog doesnt offer specs just a pic and part# , if i could know what ro mesure in my cx7 springs to compare to other springs that could help.
I am guessing my spring mesured compressed might be a thing to compare to others. I dint know if springs come in a basic diameter , or else. Any help helps.
Old May 13, 2023 | 11:59 AM
I am guessing my spring measured compressed might be a thing to compare to others. I dint know if springs come in a basic diameter , or else. Any help helps.
My information was for MOOG. There is very few and extremely rare for any auto manufacture to freely give or to obtain engineering specification on anything.
IMHO based on your responses I recommend that you simply find an application for exactly your year model and chassis type.
Finding suspension parts off applicated information is really on an experience level of knowing more then just simple specifications of the part.
The basic spring information is weight/ load specification, extended and collapsed or spring bind specification and spring coil diameter.
Old May 13, 2023 | 12:08 PM
Enriquecx7's Avatar
Thanks
Old May 13, 2023 | 12:13 PM
Thanks
I am not trying to discourage you but if you get the wrong spring even if it fits it could cause safety problems or some other adverse effect. You just really need to know and understand what you are doing when it comes to chooses none applicated coil springs.
Matt Metz
Feb 20, 2020 01:39 PM
Paul Brown
Jul 29, 2018 04:23 PM
Lydia Wheat
Apr 8, 2017 12:01 AM
joe4190
Dec 27, 2012 12:04 PM
Clnmazda3
Jul 8, 2006 05:25 PM
