2012 CX7 Turn signals cause both sides to flash
I haven't actually seen it, it's my daughter's car and I'm going to look at it tomorrow. Not seeing a typical flasher relay or anything, apparently it's all done by the BCM? Any advice on what to look for? I'm more mechanical than electrical, if you know what I mean
Thanks, but the CX 7 doesn't have a typical flasher, it has a BCM (body control module) that handles this function. The one thing I noticed is that the light on the opposite side is faint compared to the direction you're actually signalling in. That's got to mean something, right?
I did electronics in the Navy years ago. If one side is weak it means that limited power is getting through, so a dirty connection or a bad solder joint or even a faulty componant on the board may be the fault. Easiest way to fix is go to the upullit yard and get another BCM and see what happens.
