2010 Air Conditioning not cold
Old Jul 19, 2018 | 07:59 AM
jdill454's Avatar
Default 2010 Air Conditioning not cold
I have a 2010 CX-7 black paint, black interior. The A/C seems to blow cold but never cools the car off. We have recently moved to a warmer climate and i suspect that the issue is that since the car is all black and the CX-7s have a huge front window that the car is just heating up too much inside and the A/C system just isn't capable of cooling the car after its been outside in the sun for a while. I've taken it in twice and both time the diagnostics come back clean, the coolant gets recharged but doesn't seem to make it that much cooler than it was before. Has anyone else had this issue?
Old Jul 19, 2018 | 09:29 AM
wjwolfe82's Avatar
I have an '08 I bought last fall so this is the first season I've used the ac. It is a little weak...and I've read a few reviews that complained of the same. I also have a black interior and it was taking a 3 or 4 minutes and/or miles down the road to start blowing cold. I recharged it myself with a partly full can I already had and it did help some. It is still about 1/2 into the 'safe charge' zone on the pressure gauge. I plan on getting another can and max it out to see if that will improve it.
If yours is not blowing cold air, you've got a problem somewhere.
Old Jul 19, 2018 | 11:19 AM
doc4bax's Avatar
I have a CX-7 2010 and it's a freezer! ICE COLD.
Old Jul 20, 2018 | 06:59 AM
Run the AC on speed 2, face vents, recir, doors & windows closed, stick a digital thermometer in the centre vent. Depending on ambient temps you may need to let it run for 10 -15 minutes. Watch the temps as it cycles, should get down to about 5 degrees centigrade / 40 degrees fahrenheit, & cycle up to about 7c / 45f
Go for drive at medium to high speed & monitor cycle temps.
RyKerZ
Apr 19, 2011 05:23 PM
bacoli1
Aug 10, 2007 07:39 PM
swcejk2002
Jun 18, 2006 09:40 AM
the_gray_mazda6
Apr 3, 2006 12:47 AM
was98strat
Mar 30, 2006 09:46 PM
