2.0 or 2.3 ecoboost block for cx7 turbo
Old Mar 1, 2018 | 03:38 PM
wdcx7's Avatar
Default 2.0 or 2.3 ecoboost block for cx7 turbo
has anyone tried using the short block from a 2.0 ecoboost and using the heads from our cx7.
Curious to know if anyone has tried this.
thanks.
Old Mar 1, 2018 | 04:55 PM
shipo's Avatar
thanks.
Curious, what is the reason for this question? Did your 2.3 die?
Old Mar 1, 2018 | 09:02 PM
wdcx7's Avatar
Yes 2.3 is dead... have been considering swapping out the 2.3-turbo for a 2.5 with transmission and wiring. will lose some power but have less trouble.
any thoughts.
or even a ford 2.3 eco with tran and wiring.
thanks
Old Mar 2, 2018 | 04:27 AM
Ecoboost series of engines are a totally different to the old LF/L5/L3 series.
Ecoboost is a ford only design.
Old Apr 1, 2018 | 05:44 AM
duckboy's Avatar
I just swapped a 2.5 and 2011 interior in my 2008 shell. I tried to get the 2.5 stuff to communicate with the 08 interior but wouldn't. The 2010-2012 interior will fix 100%. Only difference i found is there is no holes for the Bluetooth module bracket
Old Jun 26, 2018 | 06:18 PM
wdcx2007's Avatar
I like the idea of a 2.5 in 2007 shell.
what did you have to do.I know the 2.3 have a 6speed transmission and 2.5 use a 5 speed. did you swap out the tranny too.
how about the computer to run the 2.5, did you rewire, please specify. very interested in doing this swap.
can you give us a write up.
thanks
Old Jun 26, 2018 | 06:25 PM
wdcx2007's Avatar
2.0 ecoboost engine from ford uses the same/simular block but different heads than the 2.3 Mazda that's my understanding.
got the following form the ford winkipedia page.
A 2.0 L version was first seen in the 2008 Ford Explorer America concept.[30] The engine was rated at 275 hp (205 kW; 279 PS) and 280 lb⋅ft (380 N⋅m).It is the first EcoBoost engine to include twin independent variable cam timing (Ti-VCT), with advertised 10–20% better fuel economy while maintaining the performance of 3.0 L V6s.[31]
[32]This engine is derived from the 2.0 L Mazda L engine block used by Ford in the North American Focus MK3, but equipped with unique heads, fuel injection system, and Ford's Ti-VCT. It should not be confused with the Mazda 2.3 DISI Turbo, which also features direct injection along with turbocharging, but shares little else aside from the same engine block.The 2.0 L EcoBoost engine used in North American vehicles is now produced at the Cleveland engine plant in Brookpark, OH.
jacobske
Jan 30, 2018 08:05 PM
UseYourNoggin
Jun 11, 2013 08:12 AM
UseYourNoggin
May 23, 2012 08:53 AM
bluemazdaprtege
Jul 2, 2010 05:01 PM
crusty67t2
Nov 26, 2008 01:06 PM
