Warning pings after car is turned off?
Old May 2, 2022 | 02:25 PM
eastbay driver's Avatar
Default Warning pings after car is turned off?
I have a 2014 CX-5, after I shut off the ignition and open the door the dashboard sounds a double ping with no specific warning light. This does not allow me to lock the vehicle. I’ve had to restart the vehicle, shift the car into drive and back to park to shut down successfully. Sometimes it takes more than one attempt. Has anyone else experienced this issue?
Thank you in advance
Old May 4, 2022 | 05:56 AM
Very common problem on older CX-5s. More than likely you need a new Park position switch.
This link is from Australia, which have RHD vehicles, no idea if LHD vehicles have a different part number.
https://www.ebay.com.au/itm/30392146...frcectupt=true
Old May 4, 2022 | 09:20 AM
Thank you very much for the information, I will look into that switch and let you know how it goes. Thanks again.
Old Aug 3, 2022 | 01:40 PM
Finally got around to replacing the park position switch. Easy fix. Hardest part was disconnecting the electrical harness. Thank you for pointing me in the right direction.
Old Aug 4, 2022 | 05:01 AM
I'm glad I could be of assistance.
busted626
Jan 27, 2022 10:14 PM
BMX Hauler
Nov 6, 2019 10:24 AM
Pep
Jul 10, 2017 06:19 AM
tallbarb
Apr 19, 2014 02:28 PM
megapenfreak
Jun 24, 2012 08:10 AM
