Transmission
Its how MYTHs grow on the WWW !
GAsierra I respect what you did once but you did age yourself!
In the end why did you post when you got great customer service form your dealer and MAZDA what was the point?
You gave little information to show what happened and in the end no one will ever know if it was a defect or something you did!
Ok well aside from my freind GAsierra that still needs to tour a modern auto manufacturing plant lol , the "really" comment you made still does not point to a defect from a manufactured transmission. I looked for TSB and other empirical DATA that would at least cause some to go go hmmm?? but NOPE. Now because it is on a forum it will get added to some one else down the road that will find your thread or response and say look it happened to this guy there is a problem with MAZDA transmission. LOL All you really pointed out is that someone sold MAZDA to warranty the transmission for you. This subject on many warranties goes far beyond what most think is covered by a manufacture and what get credited to a dealership on claims. Unless someone works for a dealer ship in the management level that deals with this even for me it is far to much to try to type and explain. I know we have one member that is a MAZDA Trained Mechanic that can support a little what I am saying should he read this thread?
Well, I bought the CX 5 partly to avoid CVT. That a reputable brand has a transmission that fails for reasons unknown at under 1K miles astounds me in this day /age. That is why the "really ?" At least now I should get the 2021 tranny and maybe the problem has been eliminated.
What were the symptoms of the failure?
2019 XT4 150 Miles and A/C inop; evaporator leak - one of the worst dashes I had to remove in my 36 years of wrenching. I think I had 20+ Hours in it. (The ATS isn't much better!)
I forget which GM engine but there was possible metal flash in the oil pump housing so we had to drive it (a new unsold vehicle) in a proscribed manner and if it started making noise get it towed back and replace engine.
Certain 2021 engines in GM trucks had a possible valve problem (if I recall correctly) and we had to run them at 2600 (I think; somewhere around that RPM) for several Hours while monitoring it for signs of distress. If it passed change the oil and put it back on the lot.
Just before I left there was a notice about certain 2021 transmissions that might not have a clip seated properly; we had to repeatedly shift it P-R-D, D-R-P (30 times I think?) and if it developed a "shift bump" during that it got a new transmission.
A few examples and I'm not bashing GM since they were my employer for 7.5 Years those are the ones I had to draw on; I'm sure a Ford tech (or any other make) would share similar stories.
