TPMS Status
I have a 2025 CX-5 (Canadian). On a regular basis, I would like to determine my tire pressure via the display without checking each tire with a gauge. Can you help?
Regards
Regards
Unfortunately MAZDA are way behind the curve on providing LIVE TPMS on the dash. [Available on other MAZDA models].
You need to find an external solution such as I've fitted recently; displays on the app you install
on your phone; receives the pressure/temperature via sensors you screw on each wheel.
https://www.ebay.co.uk/itm/177830392960
I use a OBD2 to wifi adapter and the OBD Fusion app with the Mazda Enhanced Diagnostics option to view my tire pressures and much more in real-time.
No need to add sending units to the valve stems this way; the information is already there; Mazda just chose not to display it on the app.
