The steering wheel become heavy all of a sudden
Old Jun 9, 2025 | 06:45 AM
TCBL's Avatar
Default The steering wheel become heavy all of a sudden
Hi everyone,
I have a 2024 cx5 AWD 2.5L.
A bit more than 3000km
The steering wheel become really heavy all of a sudden. Anyone knows why or has experience this before?
Thank you very much
Old Jun 9, 2025 | 09:49 AM
Depends on the situation and condonations of the road and driver input.
Well, you need to check the usual things first, mainly tire pressure. If that is where it should be and given that it is steering, you should ASAP go to service shop or Mazda and have your Mazda inspected. This would include the steering and suspension which both can affect how the steering reacts. Givin that you should still be under *WARRANTY (*only you would know this) I would go to MAZDA first!
Old Jun 9, 2025 | 10:11 AM
TCBL's Avatar
Thank you for your advice, I will check the tire pressure and if pressure looks fine, I will go to Mazda
Old Jun 9, 2025 | 11:42 AM
Thye way to properly check them is early in the morning with no sunlight warming then and either no or as little as possible driving which all these change the psi higher then static.
It also good if you use a quality gauge and can check it accuracy with a known accurate tire pressure gauge. Generally high-quality psi gauges are not inexpensive and run starting about 30 USD
This one I purchase 4 for the service shop (ASE) I manage (one for myself) and these were verified at the engineering machine shop with calibrated psi monitor to be accurate to .001 psi. (the advertised testing results were claimed .005 so independently tested they are better than they advertise).
Amazon.com: JACO Superior Products ElitePro Digital Tire Pressure Gauge - Professional Accuracy - 200 PSI : Automotive Amazon.com: JACO Superior Products ElitePro Digital Tire Pressure Gauge - Professional Accuracy - 200 PSI : Automotive
foxleybob
Jul 21, 2023 06:42 AM
Delta1204
Oct 14, 2022 03:23 AM
BLAlley
May 21, 2021 04:30 PM
Eli Sasonov
Jun 22, 2020 12:21 PM
mazda-rio
Jun 18, 2019 03:25 PM
