Shift lever
I purchased the 2019 CX5. The lock button on the shift lever does not work. With a slight tough it easily shifts into neutral. I was told by the dealer it’s supposed to be that way; so I asked why is it there? I was told to move the lever to the manual. Unfortunately it slides into manual without the lock button being activated.
Anyone else have this safety issue?
Thanks!
That's a good habit to break. It can be especially bad if you drive a manual as it can strain the transmission if you put pressure on the shifter and cause wear.
