Replacing headlight assembly
Old Oct 7, 2024 | 01:33 PM
2019CX5's Avatar
Default Replacing headlight assembly
New here. 2019 CX5 LED headlight went out. Fuses are good, turn signals wok. New assembly on order. What other bulbs should I replace while I have everything apart?
Old Oct 9, 2024 | 03:55 PM
I would only replace bulbs that are not working/functioning.
Most of these are sealed units and are very expensive to replace, no point in doing so unless it is no longer working.
But if you have the money and don't want to remove the trim again you can replace all of them at the same time.
Old Oct 10, 2024 | 08:04 AM
Point37's Avatar
can you get to the bulbs easily to replace them?...was curious about this process since my current car '13 subaru legacy would blow bulbs all the time and i would have to take the wheel off and go through the wheel well to replace a bulb...
Old Oct 10, 2024 | 08:26 AM
It is not easy to get to most bulbs on any modern vehicle including the CX-5 which the video shows.
I would not replace a bulb or sealed unit until it no longer functions.
But I no longer do any of that myself, so I'm not concerned with removing the bumper cover.
As I said you can spend the extra money to replace perfectly good bulbs and sealed units when you have the bumper cover off.
Though unless you have money to burn, I don't see why anyone would.
Old Oct 10, 2024 | 06:33 PM
Alexmed2002's Avatar
https://www.youtube.com/watch?v=V9RSvVUBs7Q
Ah yes I know the pain you're referring to with the Legacy. I had the same year and model, and ended up with scrapes all over my arms. But to answer your question, I linked a website below that I use for maintaining my vehicles. It's really helpful, and the guide for the parking light shows taking off the front bumper and headlights.
https://www.carcarekiosk.com/videos/Mazda/CX-5/2019
Old Oct 11, 2024 | 10:28 AM
Point37's Avatar
i agree...i typically just replace bulbs when they go but i'm ocd when the bulb colors don't match so i sometimes would have to do the other the first time it happens...after i get set on a set of bulbs i just keep buying the same ones so i don't have this issue
i got very good with doing it by feel without looking (since you really can't see)...once i switched to hella long life bulbs the replacements got less frequent...light output was not great though...
thanks...very helpful...that will be going on my computer bookmarks
https://a.co/d/bSHRpIn
Wolfcooper
Jul 22, 2023 02:35 PM
PedroMarco
Mar 6, 2022 05:45 PM
Xvenom82
Dec 26, 2021 06:55 PM
helpwithmymazda
Jul 14, 2010 10:07 PM
dulcetcalamity
Dec 1, 2006 03:00 PM
