Oil change advice and new tires
Old Jun 15, 2022 | 11:34 PM
Dpthom's Avatar
Default Oil change advice and new tires
Greetings....looking for advice please on oil change for a 2016 Grand Touring, 35,000 miles - is there a special oil (full synthetic, brand?) and oil filter I should request? I've not had an oil change in about 15,000 miles. I'm having the oil change done at my local Pep Boys. I installed a new engine filter myself a few days ago.
Also, I'm having a set of Continental CROSS CONTACT LX25 225/55R19 tires fitted by Pep Boys (ordered on Amazon $200 each) - anything I should keep an eye out for when they're installing them? I still have the original Toro OEMs which have been the harshest ride I've ever known on any car I've ever driven so defo looking forward to the Continentals.
Thanks,
Old Jun 16, 2022 | 12:31 PM
Dennis Wendt's Avatar
Thanks,
Synthetic oil is most always a good choice; any brand will do, even Wal-mart house brand (SuperTech). You should consult your
owner's manual about miles, you are way over. 7500 for NA engines, 5000 for those with a turbo.
Any major brand oil filter will work, I personally go oversize with a Fram XG7317.
My 2¢
Old Jun 16, 2022 | 01:18 PM
Dpthom's Avatar
Thanks for you help. Very grateful.
Old Jun 17, 2022 | 12:37 AM
Dpthom's Avatar
Is there any way of checking for damage to the engine internals due to lack of oil change?
Old Jun 17, 2022 | 10:04 AM
Grouch's Avatar
Thanks,
If you changed the filter but not the oil, it's now full of old oil. When you change the oil, you have a filters worth of old oil in there. I'm not really comfortable running 5000 miles on an oil change. I always changed it at 3000 but with the cost of synthetic, I'll go with the factory manual. 15,000 isn't a good idea. Oil does a lot of things. It grabs and holds contaminants. It lubricates and cools bearings. Like another poster said, how much damage was done to the internals.
Old Jun 17, 2022 | 12:20 PM
Here's hoping by engine filter he meant "air".
Otherwise, I doubt there is much if any oil showing on the dipstick.
Old Jun 17, 2022 | 12:51 PM
ALAN553's Avatar
well we are now in he 21st Century of synthetic oil…Amsoil makes a 25,0000 oil and a 15,000 mile filter or one year, as does Mobil 1 and many other manufacturers. Make the change, and save yourself time and money, or not…but the science and the options are there.
Old Jun 17, 2022 | 01:02 PM
Dpthom's Avatar
Thanks Alan.....
Old Jun 18, 2022 | 05:53 AM
kaehlin's Avatar
I wouldn't worry about premature wear or damage. Prolonging the oil change interval wasn't a great idea, but is not likely to do any significant damage if done only once. As long as you keep up with oil changes at the recommended interval in the future, keep an eye on oil consumption in case it burns a bit of oil now...not much you can do, even if there is a bit of additional wear due to the long interval.
Old Jun 18, 2022 | 06:18 AM
GAsierra's Avatar
A reasonable method for evaluating early signs of wear might be via chemical analysis of your oil. It can analyze the contaminants of various compounds and heavy metals in the oil from your vehicle, and (if you do them every so often) compare those changes over time.
https://www.blackstone-labs.com
As suggested earlier, I doubt much impact occurred from extending the interval just once, assuming the car's computer didn't complain of things and so long as the oil level wasn't too low to cause serious damage.
