Mazda cx-5 2014 diesel 2,2l
Old Oct 22, 2024 | 01:04 PM
Amene123's Avatar
Default Mazda cx-5 2014 diesel 2,2l
P1200
Mazda: Injector Range / Performance
Status of this DTC
Test failed (most recently performed test)
Test failed this operation cycle
Pending DTC
Confirmed DTC
Test failed since last clear
Engine state when the fault(s) appeared
No data available. ALSO red rectangular symbol is not diapers
😴😴😴😴 I spand a lot
Old Oct 29, 2024 | 09:34 AM
sidooo's Avatar
This usually indicates a problem with the amount of fuel being injected into the engine. This could be caused by a faulty injector, a fuel pressure issue, or even faulty sensors (like the fuel pressure sensor or MAF sensor)
Old Oct 29, 2024 | 10:19 AM
Originally Posted by Amene123
P1200
Status of this DTC
There is really not a point to guess and please I recommend NOT to take "guessing" suggestions from members!
There are exact steps and an order to perform them to correctly identify and start a procedure to correct your issue.
The first basic step to resolving your issue is to get your ECU scanned in 3 areas and see what all the information is. PLAIN AND SIMPLE!
Old Oct 29, 2024 | 10:20 AM
Amene123
Old Nov 6, 2024 | 10:00 AM
Originally Posted by jakasspeech1
You're right!
And a dozen or more other things. Stating he is right tends to be vague. But I did get a chuckle from this and other responses from you on other threads.
Nswaine
May 6, 2023 10:36 AM
edhunter
Jan 31, 2021 09:24 PM
Joanne Sarkar
Jul 28, 2020 01:37 PM
expatCanuck
Oct 19, 2019 07:04 PM
lnwlf
Oct 16, 2012 01:31 PM
