Great video on why 20% to 30% E85 mixture with 91 octane makes power in skyactiv
Old May 3, 2023 | 12:51 PM
  #101
chickdr19's Avatar
Originally Posted by owynn.severiano
The horsepower advantage in the tests is due to the higher compression ratio, yet the SkyActive engine has a fixed CR and a fixed boost value.
So are you saying Mazdas hp figures for 93 octane are false?
Old May 3, 2023 | 01:20 PM
  #102
It's difficult to honestly verify anything, from any product manufacturer, without independent testing from several sources.
Almost every auto maker has faked their mileage, hp and torque, emissions claims at one time or another.
Old May 3, 2023 | 01:49 PM
  #103
HighCompression's Avatar
The skyactiv naturally aspirated engine is variable compression. And the turbo is as well due to it being turbo.
Old May 3, 2023 | 01:56 PM
  #104
Looking for a fight .... LOL figures ..
Please show (if you can) how MAZDA derived at their power ratings?
As we have shown to be a fact that unless an auto manufacture participates with certification then they can post any power figures they choose!
FACT no guessing myth or speculation! Guess I need to post this information again for some that are slow learners.
About SAE J1349® Certified Power
Power and torque certification provide a means for a manufacturer to assure a customer that the engine they purchase delivers the advertised performance. This SAE Standard has been written to provide manufacturers with a method of certifying the power of engines to SAE J1349® or SAE J1995®. Document SAE J2723 specifies the procedure to be used for a manufacturer to certify the net power and torque rating of a production engine according to SAE J1349® or the gross engine power of a production engine according to SAE J1995®. Manufacturers who advertise their engine power and torque ratings as Certified to SAE J1349® or SAE J1995® shall follow this procedure. Certification of engine power and torque to SAE J1349® or SAE J1995® is voluntary, however, this power certification process is mandatory for those advertising power ratings as "Certified to SAE J1349®".
SAE Engine Rating Standard Prevents Numbers Fudging (an article on how GM will use SAE J1349® Certified Power, AEI May 2005, Vol 113 No.5, p 59 )
General Motors has become the first manufacturer to certify an engine's power and torque ratings using a newly adopted SAE standard (J2723), James Queen, GM Vice President, Global Engineering, announced during his keynote address at the SAE World Congress and Exhibition in April 2005. The world's largest automaker plans to certify all of its engines to the voluntary standard, and is encouraging its competitors to do the same. The LS7 engine for the 2006 Chevrolet Corvette Z06 was certified under the new standard this month. The 7.0-L V8 unit produces 505 hp (377 kW) at 6300 rpm and 470 lboft (637 Nom) at 4800 rpm. "The new voluntary SAE power and torque certification procedure ensures fair, accurate ratings for horsepower and torque as it uses third-party certification," said Queen. "SAE technical standards level the playing field, and this certification procedure is just the latest example of the value SAE has offered over the past century." To tout power and torque ratings as "SAE-certified," engine manufacturers must have an SAE qualified witness watch over the entire testing procedure to ensure that it is conducted in conformity to SAE standard J1349®. Third-party witnessing is the main provision of J2723. An existing SAE standard, J1349®, spells out how the actual testing is to be done. J1349® was updated last year to eliminate some ambiguities that allowed engine makers to cite power and torque ratings higher than the engine's actual capabilities. Engine makers are free to cite power and torque figures drived from testing conducted outside the scope of the SAE standards, but they may not claim the figures are SAE-certifed. "We feel that both the consumer and industry are well served by having accurate, consistent ratings from all manufacturers," said David Lancaster, a Technical Fellow in GM Powertrain and Chairman of the SAE Engine Power Test Code Committee that updated J1349® and wrote J2723. Data from a wide array of parameters (e.g., air:fuel ratio) will be collected during testing conducted to the SAE standards. SAE will create a database and offer it to industry in different packages and at different price points.
Old May 3, 2023 | 11:27 PM
  #105
chickdr19's Avatar
I don't have to post proof of anything on this forum. The figures Mazda provides are good enough for me. The way I look at it, if the 2.5T motor produces 40-63hp more than the NA motor and 125-135 more ft/lbs of torque, I am happy. I don't necessarily care what the exact numbers are. I will say, as I have said many times, there is not question whatsoever the 2.5T is way more powerful than the standard 2.5. Anyone who has driven both cars with the different motors would agree. It isn't in our minds, it is quite obvious the car is much quicker with the turbo (as it should be). The road tests also prove the difference in 0-60, 0-100 and 1/4 mile times.
Old May 4, 2023 | 09:16 AM
  #106
Its the point the stupid ignorant comment let me quote you " there is not question whatsoever the 2.5T is way more powerful than the standard 2.5" It is so laughable on a vehicle forums to members that know better!
Here is 2 hints for you..
Engine that are broken in!!
Forced induction!
Old May 4, 2023 | 03:44 PM
  #107
Old May 4, 2023 | 05:38 PM
  #108
ROLMAO you always know how to lighten up a thread and its funny sheeeet!
Old May 8, 2023 | 11:06 AM
  #109
Another side benefit of E85, the gas station pump nozzle is lighter and easier to handle then the one for gasoline. Doesn't need all the fume extraction parts.
Old May 16, 2023 | 11:33 AM
  #110
Apparently short trips can be a problem with E85
