Engine turns off but ignition stays on
Old Jan 18, 2024 | 08:55 PM
Jimme's Avatar
Default Engine turns off but ignition stays on
Has anyone had this happen ? 2016 cx5 automatic Turn off the car and engine stop but ignition stays on if you mess with it for a while out of park into park giggle the shifter eventually it may shut off . If so what was your fix ?
Old Jan 18, 2024 | 10:03 PM
schmieg's Avatar
I had a similar problem on my 2014 which was the switch on the shifter that told the system it was in Park. Had to replace the entire shifter mechanism to fix it which wasn't cheap. I don't know if the 2016 has the same shifter mechanism though.
Old Jan 18, 2024 | 10:08 PM
Jimme's Avatar
All the searches I have done I see 2013 - 2014 shifter switch but can't find anything about 2016 .
Old Jan 19, 2024 | 11:45 AM
It is possible the shifter unit is bad but more likely you'll need to replace the shifter switch.
It is a known issue with some vehicles.
SB-10105637-2532.pdf (nhtsa.gov)
The switch is part number KDY0-46-040
The part is around $65.00 depending on where you get it.
You'll need to add in labor unless you do it yourself.
Old Jan 19, 2024 | 01:32 PM
schmieg's Avatar
That sounds good for him. On the 2014, the shifter and switch were a single unit.
laurenlopez555
Mar 15, 2021 11:49 AM
johnj11
Aug 28, 2014 09:54 AM
mmf776
Apr 13, 2009 01:40 PM
larryjay57
Aug 19, 2008 01:22 AM
